最近才有加装后门喇叭的想法,车刚买回来只折腾外观,慢慢的对车有了了解后就开始折腾内部和大件了。
喇叭2欧姆50w,根据阿冰分析2欧姆易推不会失真,,一直没有时间安装,很多车友也让我上详细作业,今天中午没事就开始动手了。也看了论坛里很多车友的改装帖子才有信心能改好。
首先根据车友们的做法,截取了一段电脑主机电源线当作B柱到喇叭之间的音频线。B柱有后门喇叭预留插孔,所以容易多了。从最边上切了一排2个作为插入喇叭这头的线,还需要切一排,把外面塑料去掉,只留里面的插头作为插入B柱的线,然后把带塑料的和不带塑料的另一头连起来就变成一根完整的线了。后面两个门,所以我们需要做2个这样的线。
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_770e5a5f37cde7227985b52aadffe352.jpg)
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_1afa6176781cabd30cffcb50b2ea3abc.jpg)
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_1bc648082554c75cbc3e05d5c200ae2f.jpg)
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_24464db5c9db6b32abe74f04fd4c55cd.jpg)
把两边的倒角用刀翘起来
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_82a24d713d3a718e680b107708cbd0b8.jpg)
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_9cd5381bd79ddc02dceb8e469a6599c7.jpg)
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_6fbe2a3d07ae6fa1c54b561f78ee69e4.jpg)
剥皮后的样子
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_d996c7e787f1beda50b1c3aeed3c285e.jpg)
这样就做成了2跟完整的音频线了。
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_8882c3992e998d92cdc8e621365da5f9.jpg)
这是插入喇叭的头,左右门各一个
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_6fa4d47f4d61ac64752cf9a0bcc8c5da.jpg)
这是插入B柱的线
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_cb77667e6144c60cd5ffcdfa1a860b79.jpg)
这是中间接头,用绝缘胶布缠起来
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_9d5536986f78f61237705275fd3225ab.jpg)
这是无聊的时候拍的怠速硬币不滚动的图
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_b33db0f9c2d77f9e07a3ebc4abb9069c.jpg)
又是图,完整的2根线
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_dd168f754800d7145a089a1478ae12a8.jpg)
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_c00dfffd1bca4c3a5e71aa4308a2fc80.jpg)
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_7034a8ef5ba525686502dc9dfef396e6.jpg)
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_69649c44ec28f45b3b41b4f1ca049a36.jpg)
这个是什么,大家能猜到吗,4个每个门一个,高配内拉手,绝对正品,工厂流出的。
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_a7622c346419f07cec7cffda18ed8d70.jpg)
亮光闪闪,我最喜欢
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_a9e5c8b147c2a14d9619a5be7e872b6e.jpg)
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_b674bfc6b32bb6b287e74ee2723d4655.jpg)
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_b279d371e06fc64aab7ecaa091e5a132.jpg)
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_afc514090c787bbd49251cdc9de3154e.jpg)
通用标志,不贵21元一个。
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_8625b6b954a6c962adfbae5e263aa0bc.jpg)
主角喇叭上场了。
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_ed74ccf18d0a1bfa11cc4215e9235cce.jpg)
波士顿产的。
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_e745f7ad1da7e7f450871105e51138a4.jpg)
带高音杯的喇叭哦。
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_adca86485e0c36cf8d2e9aba4d212c96.jpg)
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_5f6ef2c5ac01f6a1c3d696950376ff1f.jpg)
把喇叭固定在门上的螺丝,因为不确定多长,先拿了几个,最后确定是5M×25的就好了。
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_b66ec095811b35e4ab2870629f1084d5.jpg)
这个上次也介绍过,相位仪是测喇叭线有没有接反,接反了纸盆向内鼓,如果声音太大会把喇叭震坏,并且接反影响音质效果。
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_4b7f238c9237a460d841f6a809a34569.jpg)
这个是为了拆门板螺丝外面的盖特意裁剪的,用的是酒店会员卡,反正没用了,剪一段5毫米宽就行。
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_c1e9546c8265052140ddff1c3cc41651.jpg)
拉起内拉手,从缺口那里慢慢插入,一直往里插,感觉差不多的时候用力一拉,盖就下来了。
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_271fe79588167bb6bbb0187d09575338.jpg)
下来后的样子
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_5fdfada7209169010649bb8ad7398aab.jpg)
另外一个门也一起搞下来
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_0eae6757ae2c234e94cb4beccd7056c5.jpg)
合影照。
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_4e270bf2d0a5a19894247d60967ec301.jpg)
关门把手这里还有一颗螺丝,用刀从缺口那里一点一点撬开。
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_419da428bfaa435d11aab96c8b8bd7ae.jpg)
用7毫米的套筒拧下来螺丝
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_43d95883e94f91df0bb3ecfc59fde0c5.jpg)
这个也是7毫米
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_d449bae16b299ff350c04118529ff127.jpg)
下面开始拆门板了。放心掰吧,不会把门板搞断
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_2888ae9b4d6d4b0fd1e5c93fbc2478aa.jpg)
我用的是专业工具,后来发现其实用手也行,从门板最下面这里,看,有一个缺口,我刚开始以为是坏了。
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_7f3b0abc3b3dc00243a9be068e74f0b1.jpg)
把手伸进去用力拉,啪啪啪,卡扣全从门上拔下来了。
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_7fd3525c13469166b9b78a0e1b827d82.jpg)
里面共计有2个线连着,一个是开门的拉线和玻璃升降的线。
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_153faa93f375cf8f59eebe9df5e77a51.jpg)
玻璃升降的线按下去拉出来就好了。
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_b5d811289750a5e4f3677103dfaf6991.jpg)
开门的拉线,仔细看白色的塑料部分,有一个90度直角的那个头,先把那里往外拉,然后从白色后面往后拉就可以取掉了。
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_9fa58f68df29c6aa88055f1c5e6d77b7.jpg)
拆掉门板的样子,升窗器是博世的哦,不错,厚道。
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_07a0c79cbfcec5d758b36b933fcce508.jpg)
有几个不愿意从门板上下来,这个时候需要一个一个撬下来,装到门板上。
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_7dec5e253d58ccf31652c8958271fa50.jpg)
把喇叭这里用刀裁掉,喇叭上面的薄膜用双面胶粘好
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_f7f5e057ab7fbe1e5b86701e964fe4e9.jpg)
然后打开前门,关上后门,B柱这里上面皮套往下按上面就掉了,然后把皮套脱掉,黑色的固定塑料再拉出来。
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_fe1938cbb2aea9a58399d3c01903efbb.jpg)
这样就拉出来了,
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_cce7fd07bbe6ab5cb21c20f6d00d0cea.jpg)
插线这个上下一起按出就拉出来了。
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_9d27b7105f48cba23d76788d67d15309.jpg)
从喇叭那头用铁丝穿到B柱,然后用铁丝勾住音频线,再拉回来。
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_5003d3869c35f3561bfad79b7cec30ff.jpg)
为了防止卡在中途,我是用双面胶缠着帖子和音频线头
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_ac30fb2d047e6c6be08d8ebc55e3677a.jpg)
这头插上线槽里,需要技巧。仔细看下,左边下面上下两个是音频线,一个红色+,一个蓝色-,如果插不进去就转一个方向插,感觉插不动的时候从后面用铁丝再往里抵下。
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_0d0424c632ffae39a52f6495db22068f.jpg)
然后把塑料塞入皮套里,塞好后先把下面卡子插入B柱,上面插入就还原了。
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_1755cc70e5fb1820c8102dd92e3c7c99.jpg)
这头插入喇叭接头,我用了相位仪测了下喇叭后确定了正负极。
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_52c1fe72980f51e29dc66c6bef48940c.jpg)
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_1af727f09ee78b35daf38ee6c967c9fd.jpg)
手机没电了,这步没拍照,先把5M螺丝从里面往外插,然后上喇叭,先把喇叭下面卡入门板,再把上面卡入,然后把螺丝拧上螺母,拧紧就OK了。我用了弹簧垫。本来我以为门板上那个螺丝孔很小,直接从外面拧上螺丝就行了,后来发现孔太大,如果用大号螺丝的话,喇叭孔又太小,穿不进去(先把普通垫片穿到螺丝上,从门板里面那个螺丝孔穿出来,然后从喇叭的孔里再穿出来,卡上喇叭,先放一个垫片,再放个弹簧垫片,再放一个垫片,最后拧上螺帽就行了,我最后拧了2个螺帽,因为在门板里面的螺丝无法用扳手固定,所以拧的时候可能会跟着转,用巧劲,用力一下一下就拧到底了)
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_68b83a1618186943a815e12e809d6772.jpg)
继续昨天:今天中午换了另外一个门,又拍了昨天缺少的照片,这是门上的防撞钢梁,够粗
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_7bb68071070a245413d5798448dc016f.jpg)
再往上看,这是钢管上面的又一个防装钢材。
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_2ddc220646e612471ae8ce47710d5c21.jpg)
接着昨天,固定喇叭步骤,先把垫片放在螺丝上
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_a7625ed50686ce77850758b96c0f665e.jpg)
从门里面穿出来
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_97385e9cf9fb8fc82416b1a0b6b8df28.jpg)
把喇叭卡上
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_abae442b2115a36c541278ad4d7471a1.jpg)
大图
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_2f422fbb4df97a0e76f9d221a50012ae.jpg)
放垫片,放弹簧垫片,再放垫片
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_cdb78e23cc56db99f9596e4406ccc334.jpg)
拧螺母
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_02fe652e81a0bc2e5e14476802d6dd8a.jpg)
拧了2个螺母,大功告成。由于熟练了,今天这个门用时40分钟搞定。
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_44b322282fcb4b84452b909d92004145.jpg)
======我======是======华======丽======的======分======割======线======
开始换内拉手了,先把门拉手上融化的4个点用美工刀削掉
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_4a9754ec652290b2ad2d0fd856582ed1.jpg)
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_b37ed05629f936eb00a82e09b82eab02.jpg)
然后拿掉低配内拉手
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_a7beac46dd700e06873acc3794b27c88.jpg)
装上高配内拉手,还需要把四个脚融化。这是工厂师傅帮忙的。
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_693ae0a000c7c09dd054b60b56b976c7.jpg)
用电烙铁融化,也不是很美观,大家有其他办法也可以。
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_b09130c63c4537f6e15dc258f1859511.jpg)
今天拆另外一个门板,考虑到昨天用烙铁融化不是很好,于是我用ab胶把4个腿固定了。效果好的很,然后把长度截短
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_d6c39793b7c8f1c571d8a61e543b6374.jpg)
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_b6bff6f1d82fd2222ac5c0c34bffdd3a.jpg)
4个脚都融化后,开始装门板,别忘记了拉手线和玻璃线哦。。先把门板上面放到原位,然后往下拉,这步骤不好描述,自己多试下就知道了。最后按下门板就还原了。装上螺丝,卡入盖子。
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_e5d478f9be833e91ec9a6d1d7e3079c5.jpg)
看看吧,和高配一样。
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_9064eecb7c05198a3396f96c2a404bd0.jpg)
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_192450ff9e533c743b53165f55cb84ef.jpg)
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_cbcb963416186f845ee46b160dbf94ed.jpg)
今天只换了一个门板装了一只喇叭,另外一个明天再装,但是步骤是一样的。大家可以参考下,如有不明白的地方,欢迎跟帖留言。我会及时回复!
更新了部分图片,两个门已经全部完工了。后门喇叭加后门高配内拉手,明天如果有时间把前门两边拉手也换了就算竣工了!
更新前门右边换高配拉手图片
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_1d046e3c246c4dc9422f80a079cb44e9.jpg)
![](http://bkimg.wangaiche.com/img_lib/2014/04/02/1112_0/img_87204e522026baf3767c76b9a5bc2888.jpg)
