![](http://dimg.wangaiche.com/attachments/2016/10/4612_201610101135591uyn4.jpg)
[quote]
![](http://dimg.wangaiche.com/attachments/photo/month_1610/161010105868f8d91ea8f0afd6.jpg)
第一步:接节气门的开度信号线与涡轮套件的白色信号线接好
![](http://dimg.wangaiche.com/attachments/remoteimgs/day_161010/201610101135193284.jpg)
![](http://dimg.wangaiche.com/attachments/remoteimgs/day_161010/201610101135197018.jpg)
测量方法:发动机转速信号线从喷油嘴处取得,几缸车会有几个喷油嘴,只需接其中任何
一个喷油嘴的信号线即可。量线方法:车锁拨到ACC档,万用表拨到直流电压20V档,
拨出其中一个喷油嘴,将万用表黑表笔搭铁,红表笔测量喷油嘴上其中一条线,当测得
电压为8V以下,则此条线即为喷油嘴信号线。当其中一条线所测得的电压为接近电瓶电压时
(12V以上),即被测量的另外一条线为喷油嘴信号线
![](http://dimg.wangaiche.com/attachments/remoteimgs/day_161010/201610101135199356.jpg)
![](http://dimg.wangaiche.com/attachments/remoteimgs/day_161010/201610101135191088.jpg)
第三步:安装涡轮主机
配件有:70直角管、主机、75-70直角、消音管、75-70变径T形管、70垫片、70铝管、70直角管、70T形铝管、70弯管、废气小管X2.
![](http://dimg.wangaiche.com/attachments/remoteimgs/day_161010/201610101135208902.png)
![](http://dimg.wangaiche.com/attachments/remoteimgs/day_161010/201610101135205278.jpg)
![](http://dimg.wangaiche.com/attachments/remoteimgs/day_161010/201610101135209469.jpg)
![](http://dimg.wangaiche.com/attachments/remoteimgs/day_161010/201610101135206438.jpg)
![](http://dimg.wangaiche.com/attachments/remoteimgs/day_161010/201610101135206215.jpg)
![](http://dimg.wangaiche.com/attachments/remoteimgs/day_161010/201610101135203076.jpg)
![](http://dimg.wangaiche.com/attachments/remoteimgs/day_161010/201610101135203784.jpg)
![](http://dimg.wangaiche.com/attachments/remoteimgs/day_161010/201610101135217955.jpg)
![](http://dimg.wangaiche.com/attachments/remoteimgs/day_161010/201610101135217169.jpg)
控制器 控制器上红色线接电瓶正极,黑色线接电瓶负极。
![](http://dimg.wangaiche.com/attachments/remoteimgs/day_161010/201610101135219986.jpg)
![](http://dimg.wangaiche.com/attachments/remoteimgs/day_161010/201610101135211814.jpg)
![](http://dimg.wangaiche.com/attachments/remoteimgs/day_161010/201610101135223333.png)
显示器
显示器直接放置在驾驶室内即可 (参考其它车型图)
![](http://dimg.wangaiche.com/attachments/remoteimgs/day_161010/201610101135228162.png)
第五步:调试
功能设置方式:
注:启动转速以冷车怠速电动涡轮不工作为最佳。
6.工作模式的设定:默认界面短按右确认键即可更改使用模式。
7.显示屏参数详情
(1)显示器内置电池,在断电的情况下可用两小时以上;
![](http://dimg.wangaiche.com/attachments/remoteimgs/day_161010/201610101135225324.png)
![](http://dimg.wangaiche.com/attachments/photo/month_1512/1512031044ac3ce3969b29590c.jpg)
关于安装
1.支持到厂免费包安装
(我们发货按车型配好所有安装配件,收到货即可直接安装不需要另购其它配件)
键程离心式电动涡轮LX3971
提升动力30% 节油7-12%
提升0.3-0.4个排量
![](http://dimg.wangaiche.com/attachments/remoteimgs/day_161009/201610091430516123.gif)
![](http://dimg.wangaiche.com/attachments/remoteimgs/day_161009/201610091430512443.gif)
![](http://dimg.wangaiche.com/attachments/remoteimgs/day_161009/201610091430517514.gif)
我们郑重承诺:
无动力及节油效果
支持15天无理由退货!
厂址:广州天河东圃珠吉街灵山东路15号东丰工业区Q栋四楼(导航搜东丰工业区即可)
键程汽车用品有限公司 赵小姐
手机:18502086031(微信号) / 13826129655
QQ/微信:1713295214
产品描述
![](http://dimg.wangaiche.com/attachments/photo/month_1610/1610091129b1b4fba0751e4041.jpg)
![](http://dimg.wangaiche.com/attachments/photo/month_1610/161009112974e3ac91dd7e9cf2.jpg)
![](http://dimg.wangaiche.com/attachments/photo/month_1610/1610091129bfef0eefffb8b855.jpg)
![](http://dimg.wangaiche.com/attachments/photo/month_1610/16100911293702d53b13a90aab.jpg)
![](http://dimg.wangaiche.com/attachments/photo/month_1610/1610091129e3c2c4674bbfbd2b.jpg)
![](http://dimg.wangaiche.com/attachments/photo/month_1610/1610091129339bc69dfe8d9b6a.jpg)
![](http://dimg.wangaiche.com/attachments/photo/month_1610/16100911290838c3d30bb25c05.jpg)
![](http://dimg.wangaiche.com/attachments/photo/month_1610/16100911291813db77ed69556f.jpg)
![](http://dimg.wangaiche.com/attachments/photo/month_1610/161009112999490ffd384d8665.jpg)
![](http://dimg.wangaiche.com/attachments/photo/month_1610/1610091129ca93f7e0ae4df2e4.jpg)
![](http://dimg.wangaiche.com/attachments/photo/month_1610/161009112965800ec50e28bb3b.jpg)
![](http://dimg.wangaiche.com/attachments/photo/month_1610/16100911290d430faeaaa3d78c.jpg)
![](http://dimg.wangaiche.com/attachments/photo/month_1610/1610091129c600d572c8eae4bd.jpg)
![](http://dimg.wangaiche.com/attachments/photo/month_1610/161009112924751eee97dfb418.jpg)
![](http://dimg.wangaiche.com/attachments/photo/month_1610/16100911296fdfe42a2702c5a3.jpg)
![](http://dimg.wangaiche.com/attachments/photo/month_1610/1610091129c511f8ab2f74c062.jpg)
![](http://dimg.wangaiche.com/attachments/photo/month_1610/1610091129b4eaca2f616c32c2.jpg)
![](http://dimg.wangaiche.com/attachments/photo/month_1610/1610091129bf9480575a8a9634.jpg)
![](http://dimg.wangaiche.com/attachments/photo/month_1610/1610091434727fb741eb830e52.jpg)
![](http://dimg.wangaiche.com/attachments/photo/month_1610/1610091129c3466c861e280762.jpg)
![](http://dimg.wangaiche.com/attachments/photo/month_1610/1610091129d031f881983c0825.jpg)
![](http://dimg.wangaiche.com/attachments/photo/month_1610/1610091129db003bdebced242b.jpg)
![](http://dimg.wangaiche.com/attachments/photo/month_1610/1610091129480796c7404a7b19.jpg)
![](http://dimg.wangaiche.com/attachments/photo/month_1610/161009142051022f22fad35cd0.jpg)
[/quote]
所属商家:广州键程离心式电动涡轮增压器
商品分类:动力引擎 > 涡轮增压套件
商品有效期:2016-10-10 至 2026-10-10
源地址:http://www.wangaiche.com/dian/store-1777-good-24184.html
