![](http://bkimg.wangaiche.com/img_lib/2012/08/02/1210_0/img_8219470262221d6a34cd582d03a36cc2.jpg)
原装预留孔
![](http://bkimg.wangaiche.com/img_lib/2012/08/02/1210_0/img_1114c86dd9983a171b284ad02329b078.jpg)
原装支架
![](http://bkimg.wangaiche.com/img_lib/2012/08/02/1210_0/img_61598ebe58328a1e1fb0b353d234f2e9.jpg)
准备工作,K1对码开关
![](http://bkimg.wangaiche.com/img_lib/2012/08/02/1210_0/img_aed3b7a1a15212fa741ef9ceacc0c3bb.jpg)
K2,接听、挂断开关(胎压开关改造,将S改成B,E子涂掉,线束改成2、3与胎压并联取电,4、6用原装插件与730线束接插,方便安装)
![](http://bkimg.wangaiche.com/img_lib/2012/08/02/1210_0/img_dbc209377cb9321174b28b352c7760e6.jpg)
将胎压多余端子接入30、31脚,并按大侠图纸串入7K电阻,热缩管封住。
![](http://bkimg.wangaiche.com/img_lib/2012/08/02/1210_0/img_b03a3686ca40f19f88df4ebe646192e7.jpg)
改造完成,准备穿线,拆掉座位,话筒线走A柱,控制线路走扶手箱。
![](http://bkimg.wangaiche.com/img_lib/2012/08/02/1210_0/img_f3aa4e53792c3225f0206130844be51a.jpg)
走线完毕,安装完成
![](http://bkimg.wangaiche.com/img_lib/2012/08/02/1210_0/img_571cc616408f386fde86788a9e83b919.jpg)
盖上上盖,是不是很协调。
![](http://bkimg.wangaiche.com/img_lib/2012/08/02/1210_0/img_31708b8731ca35faa8db6319c9a668b6.jpg)
K1开关难得使用,安装在护角旁边,比较顺手和隐蔽。
![](http://bkimg.wangaiche.com/img_lib/2012/08/02/1210_0/img_04823bf37c54574acd94ed018dc11ae6.jpg)
5053开通后,测试一切正常,诺基亚手机、苹果手机均很顺利配对,语言清晰,声音洪亮,蓝牙音频完美接入,儿子车上游戏的不肯下车。
![](http://bkimg.wangaiche.com/img_lib/2012/08/02/1210_0/img_025c4548dce5874247cf4f2c19b0304e.jpg)
灯管取电成功
![](http://bkimg.wangaiche.com/img_lib/2012/08/02/1210_0/img_06c428640d0e5d9e7e83a0cda6089d59.jpg)
来张BT特写
![](http://bkimg.wangaiche.com/img_lib/2012/08/02/1210_0/img_742a340aa7ea95be8639d51e9f50028e.jpg)
300w逆变安装于空调面板后方,位置很合适,电源从电瓶直接取电,并联1.5法拉电容于座位下,可直接了解电瓶状态。
![](http://bkimg.wangaiche.com/img_lib/2012/08/02/1210_0/img_33a48f89f944de3b44d75c0104d0d947.jpg)
![](http://bkimg.wangaiche.com/img_lib/2012/08/02/1210_0/img_11e5604f7b9864264bc5bd068f469f6b.jpg)
插座安置在手套箱位置,打孔改造就不叙述了,开关找不到带灯的,找了款有预留位置的,加LED改造。
![](http://bkimg.wangaiche.com/img_lib/2012/08/02/1210_0/img_8f8867b840f08f24783993d2ee869a4d.jpg)
最后在副驾驶空调风机的空位加装APRS追踪系统。
[] 同时问题也出现了,蓝牙与手机的通讯非常顺利,但与车载电台的匹配始终不行,过去与耳机的匹配时很顺利的,搞的直冒汗。
电台是YAESU-FTM-10R加装的BU-1蓝牙模块。
![](http://bkimg.wangaiche.com/img_lib/2012/08/02/1210_0/img_07c2aa9028c2f4baf05d94d11815392b.jpg)
![](http://bkimg.wangaiche.com/img_lib/2012/08/02/1210_0/img_069f2d7c68cf99b39c899c41ada70724.jpg)
![](http://bkimg.wangaiche.com/img_lib/2012/08/02/1210_0/img_effc19c59106d0fd32a3dd4b14ee4a82.jpg)
具体的操作如下:
Pairing
When using the Bluetooth® Headset for the first time, the Bluetooth® Headset and the
配对
当首次使用蓝牙耳机,蓝牙耳机和FTM-10R必须配对。
FTM-10R must be paired.
1.
Turn the transceiver off.
关闭收发器的电源。
2.
Press and hold the [POWER] key while turning the power on again.
再次按住[POWER]键,接通电源时。
3.
Press and hold the [VOL/SEL] key for one second to activate the Menu Mode.
按住[VOL/ SEL]键一秒钟,以激活菜单模式。
4.
Rotate the DIAL knob to select the Bluetooth® Adapter Unit you wish to pair.
旋转DIAL旋钮选择蓝牙®适配器的单位,你想配对。
Main Chassis’s Bluetooth® Adapter Unit: Menu Item “SF6BLTH R”
主机箱的蓝牙®适配器单位:菜单项“SF6 BLTH R”
Front Panel’s Bluetooth® Adapter Unit: Menu Item “SF7BLTH F”
前面板的蓝牙®适配器单位:菜单项“SF7 BLTH F“
5. Press the PTT key.
按PTT键。
The current PIN code appears.
当前PIN码出现。
When perform pairing of BH-1 Bluetooth® Headset, skipto the next step. Otherwise, set the PIN number of the当执行BH-1蓝牙耳机配对,跳过下一步。否则,设置PIN号码
Bluetooth® Unit:
1.
Following operation of step 4 (press the PTT key), rotatethe DIAL knob to set the first digit of the PIN code.
以下操作步骤4(按PTT键),旋转DIAL旋钮设置PIN码的第一个数字。
2. Press the key to save the first digit of the PIN code and move on to the next place.
按键保存第一个数字的PIN码和移动到下一个地方。
2.
Repeat the previous steps to complete the PIN code. If you make a mistake, press the
key to move back to the incorrect number, then re-enter the correct number.
重复前面的步骤来完成的PIN码。如果你犯了一个错误,按关键回迁不正确的数字,然后重新输入正确的数字。
5.
Press and hold the power switch on the BH-1 Bluetooth® Headset until the BH-1’sindicator blinks red/blue alternately.
按住电源开关上的BH-1蓝牙®耳机,直到BH-1指示灯闪烁红色/蓝色交替。
7. Press the PTT key on the FTM-10R to initiate the pairing.
在FTM-10R按PTT键开始配对。
8. If the pairing is successful, “LINK OK” notation will appear on the display. The FTM-10R will turn off and back on again.
如果配对成功,“链接OK”符号将出现在显示屏上。在FTM-10R将关闭并重新打开。
When the BH-1 Bluetooth® Headset is correctly recognized by the FTM-10R , theBH-1’s indicator will blink blue.
在FTM-10R正确认识到,当BH-1蓝牙®耳机BH-1的指示灯会闪烁蓝色。
To activate Bluetooth:
要启动蓝牙:
1.
2.
Rotate the DIAL knob to select Menu Item “F8 BLU VOX”.
旋转拨号旋钮来选择菜单项“F8键的BLU VOX的”。
3.
Press the key to enable selection of this Menu item.
按键,使该菜单项的选择。
4.
Rotate the DIAL knob to select the desired Bluetooth® function:
旋转DIAL旋钮选择所需的Bluetooth®功能:
OFF: Disable the Bluetooth® function.
OFF:禁用蓝牙®功能。
PTT: Activate Bluetooth® function without the VOX feature.
PTT:激活蓝牙®功能没有VOX功能。
VOX HIGH:Activate Bluetooth® function with the VOX feature (VOX gain: High).
声控高:启动蓝牙®功能VOX功能(高VOX增益)。
VOX LOW: Activate Bluetooth® function with the VOX feature (VOX gain: Low).
VOX功能低:激活蓝牙®功能的声控功能(VOX增益:低)。
5. Press the [VOL/SEL] key to save the new setting and exit to normal operation.
按[VOL/ SEL]键保存新的设置并退出到正常操作。
不知道730D的是哪个蓝牙的版本,始终匹配不了,望大侠们指点迷津。
![](http://bkimg.wangaiche.com/img_lib/2012/08/02/1210_0/img_c563d2004364780e286f6c3f32def060.jpg)
相对来说,把E改成B应该比S改成B更容易和美观吧。
